I’ve had similar thoughts. I don’t see any advantage to have the large CNC exposed on three sides, while some of the other tools really benefit from having a wide working area, either to move material around, or to feed in and out. I’d like to see our thinkness planer in a little more permanent position, preferably some place where it’s possible to feed in/take out at least 8’ of board.
The problem I see with moving the large CNC is the current electrical connections. The large control box on the wall + whatever power it needs. Not sure what that would require.
@Clay - I remember, I need to either find the old binder clips, or make a new set. I do have a label for you (and Alex and Tim as well).
