Time for another work table build day!
Date and time: Saturday, March 2nd, 2019, 11:00 AM - 5:00 PM
Please come in and help out! The remaining work list for each table is below, The goal for this weekend will be to finish the three tables that have been started, though drying times for paint and varnish mean that the finishing may lapse over to next week while we work on getting the next two table frames welded up.
Thanks everyone for your help keeping the progress on these moving forward!
- Kevin M.
Big Work Table #1:
2nd coat of varnish
3rd coat of varnish
Touch up paint
Standing Welding Table: -
Bolt and shim top to frame
Clean and oil top
Cut shelf and round over edges
Drill shelf mounting holes in frame
Pre-drill shelf and install
1st coat of varnish on shelf
2nd coat of varnish on shelf
3rd coat of varnish on shelf
Touch up paint
Big Work Table #2:
Grind down welds in way of shelf, top, and paper mounts
Drill shelf, top, and paper mounting holes in frame
Wire brush welds, and wipe frame with acetone to prep for paint
Paint frame black
Pre-drill bottom layer of top and install
Drill paper mounts and install
Glue top layer onto top
Flush trim top layers
Round top corners and edges
1st coat of varnish
2nd coat of varnish
3rd coat of varnish
Touch up paint
Install tube caps
Cut and thread pipe for paper roll
Install paper roll
Fab Lab Work Table: (not yet started) -
Weld top frame
Weld bottom frame
Weld top, bottom, legs, and supports together
Tack on casters
Grind down welds in way of shelf and top
Drill shelf and top mounting holes in frame
Paint frame black
Cut both layers of top
1st coat of varnish
2nd coat of varnish
3rd coat of varnish
Touch up paint
Sitting Welding Table: (not yet started) -
Weld top frame
Weld bottom frame
Tack on casters
Paint frame black
Countersink holes in top
Break sharp corners and edges on top
Clean and oil top
Touch up paint
