Hi, I am sick and tired of my crashy netgear router and am ready to upgrade. Just wondering if anyone has any suggestions for a good wireless router. I have at least 16 things that use my network on a regular basis (I did firmware updated and reverted, and I still had problems) Thanks
you guys know what’s what. What’s the dream router Du Jour.
Nebbie
I’m very happy with:
-DIR-825 rev B1 (Atheros AR7161 @ 680Mhz, 8Mb flash / 64 Mb RAM)
-Ubiquiti Nanostation M2 (Atheros AR7240 @ 390mhz, 8Mb Flash / 32Mb RAM)
-Ubiquiti Airrouter (Atheros AR71xx @ 390Mhz, 32Mb flash / 32Mb RAM)
-Buffalo WZR-D600HP (Atheros AR7161 @ 680Mhz, 32Mb flash / 128 Mb RAM)
I run dd-wrt on the DIR-825 as my primary gateway for the house.
I run pf-sense on a VM on my vmware server that acts as a gateway for my work machines.
http://wiki.openwrt.org/toh/start
and
http://www.dd-wrt.com/wiki/index.php/Supported_Devices
Should help a lot.
Ebay and amazon are great for finding inexpensive open-source compatible routers.
-Dave
Thanks Dave
I also suggest getting a UPS for your modem, router, and access point (if applicable) because I have found that this can noticeably improve reliability. I guess those little boxes don’t handle electrical instabilities very well.
Should I get one with 802.11ac
I’m going to say “no” unless all the devices you plan to use with it also support 802.11ac. Your next one will probably have 802.11ac
Right, the only thing I would use the 802.11ac for would be range extenders.
