All -
I’ve seen a couple misconceptions about my position on this topic, and my recent tinkering with the Gigabot. It seems useful to clarify.
In short summary, I’m not suggesting that the machine is fine as is, and requires no further work. I simply remain unconvinced that $500-700 worth of new parts are required, and I don’t see that the suggested part list addresses all of the primary problems. We might purchase an entirely new 300mm or 400mm printer and repair the Gigabot for the same expense.
Current repair plans seem to have been formulated at a distance based on hearsay and old documentation rather than direct physical examination of the machine. To this end, I printed a small test part on Friday. Before suggesting that the existing electronics still work, it seemed prudent to verify. In further testing Sunday night, a 400mm hexagonal base adhered so firmly that it could not be removed without destroying the underlying tape. Other mechanical (extrusion) problems appeared during this run, preventing completion of the print. The bed, however, while slightly cupped is not as catastrophically warped as we have assumed.
I also found a MAX6675 thermocouple amplifier board hanging off the heat bed, as mentioned in old wiki documentation. I believe, but have not yet fully researched, that this is the missing piece required to re-enable the heatbed.
I’ll avoid belaboring this point by point, but suffice to say a detailed review of the printer would be beneficial before building a parts list and committing member funds to a repair effort. And because I’m uncomfortable being the asshole who torpedoes a vote and walks away without improving things, I will continue to engage in configuring the printer. I’ve had multiple offers of assistance, and there certainly seems to be enough fresh interest in the machine to justify the work.
If the vote passes, I’ll be quite content to stop flailing at the keyboard and move on to other projects. We’re a large group, and there’s always plenty to be done
P.S. - Jeff S.
I chose your message as a reply target simply because it was the most recent strong summary in the thread. Please don’t consider this addressed specifically at you.
As a series of small and immaterial asides on your comments: The Gigabot is a standard Cartesian machine. 9 point bed probing is already working. The heatbed is an AC silicone mat, so power does not pass through the controller. I’d again agree that the Duet is a better board, and in isolation would remain a fine upgrade for the printer. I remain primarily concerned with total expense, and recommend identifying and following the critical path to avoid unexpected additional expense.
