I used the Dremel tonight and it was in pretty bad shape.
I would like to propose we get a nice Dremel set with lots of features including a flex shaft.
Amazon has the kit for $199
http://a.co/2zT7yih
I think this is worth discussion and a vote since it is more than $100.
Feel free to comment on this thread.
I would like to suggest you also get the adjustable chuck accessory, it eliminates the need for the different sized collets. Instead it replaces the tip with something very similar to the chuck on a drill, meaning you can use many different sized bits easily…
https://www.amazon.com/dp/B071987D1L/ref=sspa_dk_hqp_detail_aax_0?psc=1
oops, meant to add these sanding disks instead of the overpriced dremel brand ones
https://www.esslinger.com/metal-and-jewelry-sanding-yellow-disc-assortment/
The kit I mentioned has the three jaw chuck.
