Bandsaw Crosscut sled for round logs
Why do we want something like this? Because we are not stronger than the band saw.
Modified Grizzly Cross Cut Sled. Total Cost $262 and some drill press work.
Of course, Grizzly does not design compatible band saw accessories. Why? They are Grizzly. So go Frankenstein. Start here Grizzly T32839 - Sliding Log Crosscut Jig $82
Hold it to the crosscut fence with these parts 2,4,5, 9,13,26 that fit the current bandsaw fence total $81
PH7587002 ADJUST BASE $59.80
PH7587004 SHAFT $4.60
PH7588013 LOCK BLOCK $8.95
PH7587005 SPRING PIECE $1.49
PH7588009 FENCE HANDLE M8-1.25 X 22 $4.05
PFB11M FLANGE BOLT M4-.7 X 10 $1.49
Connect those parts to an aluminum plate from Grainger
Aluminum Plate 6061: 36” Lg, 8” Wd, 0.25 in Thick, Unpolished, +/-0.008 in Item 2ARH8 $57.04
Plus metal work. And It will look something like this.
