hey folks I just got here (Hive) I smelled plasticky smell, checked the Fablab and the Ultimaker was going whackadoodle - nothing stuck to the print plate and the nozzle a few inches up in the air spewing strings of black filament…
There’s a stringy pile of more filament on the floor in front of the printer… Someone’s print did a fail. I paused it and will try to figure out how to cancel the print… Is there anything else I should do to properly shut/stop the printer?
We could easily wire it for streaming on the website also, at least close to what we do for the spy cameras. I believe we have spoke about this and I’m the fablab camera was originally for that.
The real problem is that someone started a job without actually looking to see that it was working correctly before they left it unattended.
That should NEVER happen! The Ultimaker Cura/Marlin configuration has a random starting issue where it will start 1" above the build plate. The second start will work correctly. It’s a persistent issue that I’ve had with my own machine and that machine exhibits the same exact symptoms.
