Please refer to the linked list of vertical storage slots, and confirm the storage slot you are using and if you need to renew. If you are using a vertical storage slot, and your name is not on the list, please let me know which number and I will update the list on the wiki.
https://wiki.hive13.org/view/Temporary_Wood_Project_Storage
The response last time I asked was very light, so please provide the information as others are starting to need space.
Also, there is a lot of wood in the slots 13-15 reserved for general hive needs. If that isn’t claimed, I will assume it can be used for projects to improve the woodworking area.
Russel
