The small laser now stands alone. Separated from the Big Laser. Which means you can now run the blessed thing.
Steps to Operate the Small laser
Turn on the 220 Volt Power for the exhaust fan and chiller at the yellow switch box which sets on top of the chiller.
All 220 Volt lines for the small laser are color coded YELLOW
Turn on the 110 Volt Power for the laser and PC from the power strip under the small laser.
All 110 Volt lines for the small laser are color coded PURPLE
The cooling water lines now run only to the small laser.
The exhaust fan only exhausts the small laser.
Wonder if we could add the air pump to the power strip, then it would come on with the laser power.
I’ll look at it Saturday when I’m down there.
I’ll also try and make a fixture to set the correct Z height (or get the auto Z working right).
There is one 110V power strip for the small laser. The computer.
monitor and laser all plug into it. If you turn it off the computer
dies. You could use some DIN rail and the AB automation to make a real
solution. Or just chain power strips.
The small laser seems OK but the stupid software won’t read the files from the Big Laser. (I wanted to run the material test cut).
I think I can export then import. (Whee).
I wiped the small laser down and verified it’s operation.
I think putting the laser and air pump on a power strip might be a good idea. The computer could be on an independent tap.
I emptied the big shop vac and shook out the filter. The filter is the wrong size (too long) it mostly works but we should get a few correct replacements.
I also cleaned out the small shop vacs.
I thought we had an additional big shop vac?
