Due to the advent of having a welder machine and soon a huge CNC. Have we thought of looking into acquire a SANDBLASTER.
I am sure a sandblaster with help a lot welding projects.
Marvin
Marvin
There already is a sandblaster @ the Hive. It requires some work to be operational:
On a side note, this will also require that the air compressor tank is replaced (which I have in the works).
On a further side note, sand blasting requires a lot of air flow at a decent pressure. The current air compressor @ the hive will give you ~15 minutes of good sand blasting before you need to let the tank refill.
Paul
Thanks a lot
I looked at the wiki under the tool section and didn’t see it listed there so the reason for my inquire. Its nice to know we are only about $50 away from an operational blaster
Thanks again
Marvin
Aha, good point. I will work on creating a project // tool page for it on the wiki so we can document its status & what needs to be done for it.
