Problem with main 3rd floor door
We had a problem this afternoon with the main 3rd floor door not quite closing and then turning around and opening fully. After cycling the door several times the problem seemed to go away. After consulting with Dave Velzy I tried all of his suggestions. Things seemed better but since the failure was no longer repeatable we can’t be sure. So it is possible that this problem may occur again and we would be stuck with the main door wide open and unable to close it to secure the Hive.
If you are there and this happens, try these things in this order.
Contact:
John Clark COO on Slack (message or call, you did know that you can make calls on Slack)
Or email john.clark@hive13.org
Contact Dave Velzy on Slack
Email leadership@hive13.org
