Since we are getting ready to harvest a bunch of parts from the “trash” area. I would like to request that you hold a quick class on making power supply breakouts for projects. I know this is a relatively simple project but I would definitely like to build one and I’m sure a few others would as well. Having a quick ‘class’ on it, where everybody gets together to simply put some together would be awesome.
I know you talked about doing this before but I thought I would bring it up again.
I will say that after my SD project I have had a bit of experience with the personal etching of circuit boards. If we can get the board designed I think I could do a decent class on personal etching of circuit boards.
I am by no means an expert yet, but I have experimented with several different methods with varying results. The biggest thing is you need a lot of patience in order for it to turn out well.
The short answer is, not quite yet. The long answer involves us getting an isolated parallel port breakout board (we found one on ebay for ~$30 shipped)
