I left this in the electronics area.
The blue tub is to house all the learn to solder stuff as was discussed at books by the banks.
The monitor in pieces is a halfway decent Dell 24" unit. It had issues turning off randomly i.e. power supply issues. I started to repair it and then needed bench space for assembly and test of product. If I have the time, I’ll continue to troubleshoot/replace caps, etc. Or someone else can. Good small electronics repair project.
I also have a 50" Panasonic Viera plasma that has power supply issues. I’ll drag it in at some point so it can be donated, repaired and used around the space. (BigCNC monitor?)
If the monitor is unwelcome, try to dispose of it without landfill or contact me so I can remove it.
Thx
D
