Member Vote for Expansion - Audio Studio Building Supplies
Member Vote for Expansion - Audio Studio Building Supplies:
Total $3000
This Member Vote is to complete the infrastructure buildout of the Audio/Podcast/Ham Studio. The items listed below have been identified as supplies needed to complete the studio build with an emphasis on sound attenuation.
  • The walls of the studio will be 3 layers of drywall thick, two on one side and one on the other.
  • The walls will be taped and mudded at each seam on each layer.
  • The walls will be insulated with R15 Rockwool insulation (flame-resistant) with sound attenuation adhesive used on the studs and between the drywall panels.
  • The floor will be finished with Reinforced Mass Loaded Vinyl, which will uncouple the concrete floor from the vinyl plank flooring.
  • New 22mm thick Vinyl Plank Flooring that is waterproof and designed for heavy-duty use.
  • Sound attenuation foam panels will be applied to the wall of the studio. All materials are flame-resistant
  • Sound attenuation blocks will be added to the corners to provide sub (bass) traps.
  • New LED track lighting with appropriate dimming/motion sensor functions to help with noise coming from lighting fixtures (No ballasts, No filament hum)
  • Appropriate threshold plates and door sweeps for the door that will be built.
Member Vote - Audio Studio Building Supplies - BOM 2-10-26.pdf (89.8 KB)
I vote yes
heck yeah this is cool. I’m glad we’re finally making a sound room. I think it’ll get a lot of use. Let’s do all we can because the hive is loud
I vote YESSSSS
I vote yes
Yes from me
Yesss
Yes is my vote.
Dave Velzy
Yes vote!
Vote yes. This will be very neat to have.
I vote YES!
Yes from me
I vote yes
yes . .
cone of silence!
Yes vote
With 32 yes, 0 no, and 1 abstain, the audio studio vote passes.
