Dear wonderful Hive13 members,
While we are not quite ready to start moving shops over to the new Hive13 space, we are close enough that it is well worth thinking about! It’s highly likely that we will begin moving the woodworking shop over in the next 2 weeks!
In preparation for that, we (led mainly by Jeff and Jill) have managed to get the new member storage area (mostly) set up and are ready to start assigning storage spaces!
the spaces in the new building are slightly larger than the old spaces, they are each 16" wide, 16" tall, and 48" deep. Shelves A, B, C, and D each have 24 spaces in them, and E, F, G, and H each have 12 spaces, for a total of 144 spaces. The spaces are labeled with A and E being the lowest shelves, letters increasing upward so that D and H are the top shelves, and the numbers are with 1 nearest the front of the building moving higher toward the west/back of the building. you can see where they are located on the floor plan here: https://wiki.hive13.org/images/1/16/2701InitialMoveInLayout.pdf
For now, we will be reserving the top shelves (D and H) for Hive13 storage, till all lower shelves have been assigned. This means that all of the assigned spaces should be within the reach of most members, unlike our old shelves which required a ladder for half the spaces.
There will also be a limit of one member storage space per member going forward (we have been working hard to grow membership, and we don’t want to run out of spaces like we had in the current space).
If you would like to request a member storage space in the new building, you now may! We will be assigning the spaces on a first come, first serve basis. If you have a preference for what shelf you would like to be on (top, middle bottom), please include it in your storage request.
The instructions for submitting a request are as follows:
- Log in to your account at intweb.at.hive13.org
- Scroll down to the “My Storage Slots” panel and click “Request a new spot”
- Select “Member Storage Slot” from the drop-down menu, and type in a message saying that you want a space in the new building, and if you have a shelf preference, let me know. Then, click “Submit Request” and I will assign you a space.
Kevin McLeod
Hive13 Secretary
