Fair enough.
If we commit to creating a “fancy” wood storage plan then I support getting rid of the rack to organize the area.
Please explain in detail what this means to you. I’m not sure how that would differ from what we’re currently doing in the temporary wood storage. There has been some suggestion that we store plywood and other sheet goods flat. Is this what you mean?
I also seem to remember some water drippage in that corner of the space.
If that’s the issue, I think we need to be clearer on exactly how much, where, and see if we can find a solution. Water drippage is a problem no matter what we put in that corner. Depending on where it is, it might be okay, since it would be in the access around the CNC. Whatever is going on probably hasn’t been doing the 2nd CNC any favors.
Wonder if we could store sheets under the current member box rack. (Where the cardboard boxes of junk are now).
I was thinking about another shelf and then more member storage, but you’re correct it’s a good place for sheet goods, and we could probably create storage by asking people to only store one slot worth of boxes on the shelf. Right now I believe we have a few members who have multiple spots, which was fine when we didn’t have people looking for space.
Or maybe move the rack to the other end of the long workbench?
We can’t put anything of any depth there or it will interfere with the storage slots nearest the wall. Right now it’s not really possible to get anything into or out of the first 4 slots. I’ve asked people to clean out the current loose wood, which will be going onto the scrap pile on Dec 31st, at which point I might put up a pipe clamp rack, or I might not. Regardless, whatever go into that space needs to be about 6-12" deep, max.
I know one member who was storing stuff their because they didn’t have a slot, now that they have a slot I’m expecting the mess to get cleaned up.
Can we create a clamping system for the existing vertical storage area? If two or three sheets get clamped together I would imagine they could be stored vertically.
That’s a good idea. I’ve been thinking about this, but I can’t think of anything that isn’t awkward. It seems essentially a couple of the spring clamps screwed into a 2x4 would work, but I’m not sure how you would get things in/out without a ladder to climb up and release the clamps. So for now I’m going to leave it to the individual members. Nothing stopping somebody from finding a decent solution, and using it in their space. If you’ve got a solution, I’m all ears.
