It’s also light the Hive day Saturday.
Many places at the Hive need more light. It’s time to fix that problem but we need some help doing it.
If you don’t mind climbing a ladder, then we could sure use your help. In some cases we just need to change fluorescent bulbs. In others we need to change fixtures or put up new ones.
If you would rather work on the ground, the air compressor needs to be mounted. Which needs help too.
Or you always join the Let’s Make Some Doors" party.
Or even some of all three.
The lighting fun is from 11:30 until 4:00. All help appreciated.
