Came in around noon to help someone with the laser cutter.
there’s almost an inch of water underneath the wooden workbench I vacuumed up with the shop vac.
I came in Friday (2/23/2018) to work on the big laser door strut, and the tub by the window was full and there was about 1/2” of water on the floor by the workbench. I emptied the tub using the shop vac (left the filter out to dry the inside of the vac).
So the leak was still not fixed Friday.
Since we don’t use that as a window, is it worth looking outside and just boarding it up?
