I made a quick change to the laser cutter control PC this evening. There are now separate icons for launching EasyCut in the correct configuration for each of the two laser cutters.
The shortcuts can be found in the start menu as depicted. Let me know if there are any questions about this, or if you encounter workflow problems with this setup.
Bear in mind that launching EasyCut via other methods will simply load the most recently used configuration. Please use the Start Menu shortcuts henceforth.
