Wednesday we had a good turnout for the Perl Mongers meeting in the Lounge, 13 turned out, 1 had to leave. Before the meeting there was a large mirror leaning against the printer just inside the door of the lounge. I moved it to between the wall and the printer. That was much less likely to fall over and cut someone but it still isn’t the best place for it. If someone bumps the printer then the mirror will be shattered. Is there a better place for the mirror? Is it going to be mounted somewhere?
The mirror has been leaning against the soda machine for years at this point, which is a relatively safe place for it. Leaving it against the printer is a bad idea. Thanks for making it a bit more secure, I’ll look for a better place for it asap.
