This is a highly used resource. Let’s get it done sooner rather than later.
Proposed Purchase
2 EFR or RECI 100W CO2 laser tubes. ~$800-$1000
Shipping costs will be high due to the length of these tubes (1.5 meters).
It would be cheaper to purchase a spare tube in the same shipment to save money, as well as prevent future down-time.
I have inquired with LVL1 and other spaces to see if they need a tube at this time and are interested in lowering cost with a group buy.
I have inquired directly with EFR and RECI, as well as resellers. I am waiting for quotes to come back.- Electrical repair parts. $200-$400 (worst case – IF a new HV power supply was needed)
Mirrors, lenses, and other replacements $50
Industrial controls / safety & protection $100-$200
Coolant flow switch. ie. https://www.aliexpress.com/item/water-sense-to-protect-the-laser-tube/1361956447.html
Overcurrent relay or similar protection to fail safe if tube limit is exceeded.
Over-temperature switch.
Coolant level sensor.
Proper wiring & status indicators to insure that laser is ONLY operable with all systems functioning.
Padding for shipping costs, duty, etc. $400
I am requesting $2050 for this vote. Hive13 currently has 30,000 in the bank (fanance.hive13.org). This maintenance represents 6% of that balance. Based on previous trends, we can expect to offest this expense and restore this balance within a period of months, not years.
It is likely that this will cost less. This is a conservative estimate, which allows for unexpected expense and possibility of further failures. Most likely, it will cost less.
I am working on logistics, research, planning. Bill Steele has volunteered to lead the installation. He is the most qualified person to do this. Thank you Bill.
I will update everyone with more information as I gather it. I will not be round this week, but wanted to get this process started anyway. I will be able to answer limited emails this week, and will be back next Monday.
