I ordered a new sensor for the laser and with the help of Lorinn, We now have a working Z sensor!
Tested and confirmed the bed actually stops instead of seizing up and causing problems.
A 330K Ohm has been placed inline on 24V and Output wires. This will be helpful for the next person to replace a sensor.
Where did the super cool red piece come from? Is that the sensor or a holder?
I also think we need to replace the main focusing optic in the laser head. It has a crack in it.
I think they are only around $20 on ebay/amazon. Just need the focal length and diameter.
Elly and I looked it up a while ago, they are pretty common. We should order two. I’d be happy to put it on the warden spreadsheet or at least spec out what we need after the meeting on Tuesday.
I didn’t look into the Z sensor.
Let’s work with what we have. We can also work on getting the non contact sensor online.
You should present a receipt to get reimbursed.
Bill, the sensor appears to trigger against various material types, I tested Acrylic, aluminum, and some scrap wood.
Acrylic
Wood
Aluminum
I believe before we formally go using this on the mainstream we may want to replace the other portion of the connector as the pins slide pretty easily. I left it unplugged for others to look at during the meeting.
I think the trick was the 330K ohm pull up resistor. This sensor had great performance at the bench test, but did not play well with the laser electronics. It needed a fairly high load resistor to bridge the load & pull the open collector high. I wonder if the omron would not work better that way too.
But yes, this one would have snapped too without the added pull up resistor.
Bill also may be referring to the sensor slipping out of the bracket from repeated “presses” (vibration, in which case, I would advocate adding some loktite medium strength to the set-screw.
