When trying to use the large laser I am getting an error I have not seen before. When trying to test the file after sending it from easycut It beeps and says “DLL VERSION DOES NOT MATCH FIRMWARE VERSION.”
I am helping Hank with his arcade system. The cut is set from a dxf exported by AI. I imported it into the easycut_big_laser. downloaded it, then went to cutter and hit test.
Any assistance on what I may be doing wrong or what could be causing this would be appreciated.
