I have been looking at Tool sharpening options for Hive13 so that we can sharpen things like planer and jointer blades, chisels, hand plane knives, Lathe tools, etc. on site without having to order replacements or sending things out to sharpening shops.
The system I have been leaning toward is a low speed benchtop wet grinder and polisher similar to the Tormek system. WEN sells a copycat of the Tormek T8 at a small fraction of the price ($120 vs. $720), with the only significant difference being that the WEN does not have the micro-adjust feature on the tool rest.
These low speed wet grinders can provide vastly superior edges on tools when compared to using the typical high speed grinders like what we currently have, and are far less likely to overheat the tools and ruin the temper of the steel. Sharp tools are safer tools.
The WEN is also compatible with all the Tormek accessories, and to get maximum usage at Hive13, I’d suggest getting these accessories:
Turning Gouge Jig and Micro Adjust tool rest set ($205): https://smile.amazon.com/dp/B00ZFO9N54
Knife/Scissor/Axe/Carving Gouge Jig set ($225): https://smile.amazon.com/dp/B00MA0KBTS
Planer/Jointer Blade Jig ($200): https://smile.amazon.com/Sharpener-Tormek-Sharpening-Precisely-Virtually/dp/B00149FIFI
I wanted to put this up for discussion prior to making a vote thread, because I know some people have very strong opinions on tool sharpening methods. If you have convincing arguments for another system, please post it and we will discuss. The Tormek accessories are pricey, but by all accounts make sharpening reliable and easy. The total of what I listed above would be ~$750, though the accessories could potentially purchased on seperate votes at separate times if the total is objectionable as a one-time buy.
I’d like to put up a vote thread for whatever we settle on next week to be voted on at the following week’s meeting. We currently have several tools in the wood shop in desperate need of sharpening (planer, hand planes, chisels).
Kevin
