404 Not found Warning: require_once(/etc/wordpress/config-hive13.org.php) [function.require-once]: failed to open stream: No such file or directory in /etc/wordpress/wp-config.php on line 16
Fatal error: require_once() [function.require]: Failed opening required ‘/etc/wordpress/config-hive13.org.php’ (include_path=’.:/usr/share/php:/usr/share/pear’) in /etc/wordpress/wp-config.php on line 16
I’m aware of this problem and I’ll see if I can get it resolved between getting out of work and the meeting. If I can’t get it resolved by then I’ll shanghai Craig, Starbuck, and Foxydot to help me out.
The issue is there is no redirection from hive13.org to www.hive13.org on the colo box. Wordpress looks at the requested domain name when your request hits, and it serves the appropriate name’s content. www.hive13.org is defined in Wordpress, hive13.org without the www is not. Use www.hive13.org for now…
Ok, it works…sort of. It 301 redirects to http://www.hive13.org. I guess that is the expected behavior.
BTW, I may know a bit about this kind of stuff so just let me know if you need any help. ( just to be clear…“help” like: “having more people to do stuff makes less work all around”, not “help” like: “you don’t know what you are doing and need someone else to do it for you”.)
So long as it’s transparent to the end user, the solution works for me. Here at work I don’t even see the redirection, I just magically end up at www.hive13.org.
Well, according to SEO rules, it's better to only use one of http://hive13.org or http://www.hive13.org anyways to avoid duplicate content. I don't think it matters which one, as long as one redirects to the other, which it's now doing.
