I have been using Kevin S.'s CR10 to print some models for work. The last few models have failed to complete, apparently because the heated bed is failing intermittently causing the parts to detach from the build plate.
I am not sure how to go about diagnosing and/or repairing the heated bed. Does anyone have any Idea of what steps I could or need to take? Would anyone with experience with these things mind coming in to help me out (I’ll be in tonight and Saturday)?
I am likely going to have to build an enclosure for the printer as well as get some decent build tak / bed adhesion material. The printing material and company can also cause some frustrations with adhersion on large prints.
Ryan might know what is up with it best then. He was using it for a bit before he brought it down to the hive. I have not printed on it for a long while so it could be the bed element, board, or firmware. Did you try heating the bed manually in thr menu options when not printing to see if it would warm up?
I disassembled and reassembled the bed and control box to check all the connections, and visually everything looked good. I reassembled everything and it heated for about 10-15 minutes then stopped and cooled back to room temperature. I don't know if it's the cable, or the MOSFET board, or a connection I missed, but it's trying to heat to 45 degrees, but not actually getting warm now.
It sounds like the issue isnt the thermostor then, The Mosfet could have blown as well as a broken wire. (Heating element is possible, but not as likely based off of what you said.)
Used a IRF3205. It’s a bog-standard N-FET. I am 99.9% sure I have something that is several orders of magnitude more efficient / less heat-dissipating sitting around.
