My kids and i have started to work on a DIY arduino with 328P to use injunction with a led cube display. The goal use this diy ardunio to control the display cube connected to the header pins. I need some assistance with the final wiring of the diy ardunio board section, can anybody share a simple wiring of the board would be greatly appreciated.
FYI nothing has been soldered yet and I am missing the 16 mhz crystal
When I get home I’ll send a schematic for one I’ve built.
What I found was missing from this and other older schematics is a capacitor that goes with the reset line to allow the serial programmer to reset the bootloader to accept new code. Without it you are supposed to be able to hit the reset button to upload a new program, but I could never get it to work.
Do you have an ATMEGA with a bootloader already on it, or will you be programming that yourself?
Yes, I have already created a bootloader atmega 328 using two ardunio uno’s one acting as the master the other acting as the slave. Since this will be a one time upload sketch for the led cube display I opted not to install an fdti
