I opened the car scanner the other day and there is a breakout with several pins including JTAG. I want to make a connector for this. However I do not know what those style connectors are called so I can’t order one… does anyone know?
The breakout port is in the upper left (just in case you are wondering)
That looks very close to the pitch of a 5.25" floppy drive. I keep a handful of such cables around for making edge connector → 0.1 x2 row cables. There are some at the hive too.
-Dave
Good idea. I’ll start with a floppy connector but knowing that it is called a PCB Card Edge Connector is very helpful! I’ll measure it out and order one if the floppy connector doesn’t work. Thanks!
