Actually I have tired to do it myself using eagle but I guess it out of my personal skill level.
What I am looking is as follows
Use the relay .sch and .brd and remove the SD and xbee optional and any wiring. The object is to create 4 channel relay module with a female socket to put a microduino core on top wired to the relays on the board
AFAIK, there isn’t an ‘easy’ way to do what you want to do.
If you copy the board layout, you’ll end up with an inconsistent schematic.
If you copy the schematic, you’ll end up with an unrouted board for the piece you copy.
How many relays do you want total? If you’re going to go through this work, you might want to think about that first.
That’s my problem with my skill level with copying and pasting doesn’t work.
I actually want a 4 relay and 8 relay module. I picked the attached sch because I like how they grouped everything together. I also bought the microduino from a kickstarter campaign so I want to make one module …
My skill are very limited is this area so the reason I am asking for the assistance .
