Now that the Hive has a big CNC router, I was wondering if there is interest to use it to mill MDF to make smaller “home-size CNC routers” (for a nominal fee).
I’ve lusted after one that could take a 4 ft x 4 ft panel, but realistically my garage can only handle a 2 x 4 ft.
I’ve had this book for a few years now: https://buildyourcnc.com/Book.aspx
I’m not sure if that book design is up to current “Maker” build standards, but perhaps others might be interested in working on a design or a series of different sizes depending on interest or budget—for example, using the book’s homemade linear slides or buying proper ones. It might be worth designing starting with a 4x8 or 4x4 MDF sheet and trying to maximize the table size and minimize waste wood.
My interest right now is a 2x4 or 2x2 ft capable CNC router with minimum cost. I’ll bring the book to the Hive for a Tuesday meeting in the next few weeks so others can see the plans. If I can find time I’ll try to sketch some ideas for filling a sheet with minimum waste. (I could fit a 4x4 ft in my garage if it could be broken down a bit and stored with the table vertical.)
Does a design like this already exist? I wouldn’t know where to start looking other than google, and my first searches haven’t found anything.
Matthew
(not a member!)
