The CNC router Speed controller is not responding properly!
When I press F5, the spindle comes up to the set Speed.
When I start the GCode, the spindle speeds up to 24000RPM!
The only thing I can do is Stop the GCode to stop the Speed over run.
Any prior cures for this?
I’ve restarted the hardware & Mach3 both, to no avail.
Try using the profile “Test”. This was a copy of the original Large CNC file which I then manually calibrated the spindle, I am yet to have the spindle radically speed up on this profile.
I have seen the large CNC profile act up on multiple users as well as myself.
