I crashed the CNC while cutting a part earlier today. There was an e-stop while running a cut, and when I cleared the faults I accidentally moved the gantry instead of raising the z axis up.
Everything seems to be working, but I'm afraid I racked the gantry, and I'm not sure what/how to check everything. Could someone more familiar run through it to make sure I didn't mess anything up, and help me fix it if I did?
I had several e stops in my cut on friday evening. They all occured with the x axis near the center of the board and the y axis near the center as well.
It even tripped on me twice when I was just getting the spindle up to full speed after it had tripped stepping up for a tab, running the resume from here command.
Always reset and page up.
Do you remember where the e stop occured on the board? Center, top left, etc.
