I want to let everyone know that I’m taking the CNC offline for a little while. I’m working on finishing both CNC machines so we can get some classes going. If someone needs to use the CNC please let me know and I will work with you to make sure the larger one is operable at the time you need to use it.
I am mid-project. Already made 2st cuts Saturday. I need to finish the cutting on Tuesday afternoon.
Also, I might have left my 1/4" bit and flash drive on the computer. FYI.
I’ve gotta get this thing done, and have all the GCode tested and ready to go. Will only take half hour (and just a couple minutes for the cuts). Can I do that Tuesday afternoon - 3pm-ish)?
Thanks man. Also if you see that bit, hold it for me. It’s identical to the coy bit (clear tube, red cap). I think it may be the same brand… I hate losing end mills…
I have only small, simple pockets to cut. I appreciate being able to finish up.
The ball is in my court on this one. The software has been purchased, and there is a registration process for me to complete. I will try to get to this today.
