Clean up Saturday - 2-8-25
CLEAN UP SATURDAY UPDATE **
2-8-25 - 10 am ish until whenever you need to leave.
Mike O will be leading the charge this weekend and he will be onsite from about 10 am until 2 pm. If you can only be here later than that John C will be around to help after Mike needs to leave.
Updated todo list items with priorities listed in order:
  • Prep for Floor painting in the CNC area
    • Vacuum the floor
    • Wet mop the floor with clean water (Change water often)
    • Let dry
    • Coat the floor with sealer/primer
  • Move power tool drag racing items from near the OG restroom to the back of the hive. (See attached photo)
    • Move brewing equipment from the wall
    • Move all items including banners and graphics
    • Place them in the highlighted area in the photo
    • Sweep the floor where the items were.
  • Add OSB to the last member storage rack
    • Cut List for Decking IJKL racks.
    • Rack IJKL 7-12 is a 48 x 96 rack. Put the two full sheets on this rack on the lower shelves.
      • The rest will be done with salvaged OSB sheets in smaller sizes.
    • Pieced together to finish the decks. The OSB is leaning against the South Wall on the Left as you pass through the tarp to the back.
    • Deck the top of IJKL 7-12 with qty 1 38.5" x 86.5" OSB standing up on the south wall.
    • Cut two 9.5" x 86.5" strips and splice one to finish the 48" width
    • Deck IJKL with the rest of the 38’5x86.5 OSB - Cut one sheet into qty 4 6"x86.5" strips and another sheet into qty 4 9.5"x86.5" strips to
    • Attach to stringers with drywall screws. Make surfaces level.
  • Empty the Skid bin into the trash compactor and return the skid back to the dungeon
  • Vacuum EVERYTHING! Ductwork, Light fixtures, Floors, Walls, windows.
  • Clean windows
    • Vacuum
    • Wash (Squeegee and window mop are on the ledge by the washer and dryer
