I made a big (40" wide x 15" deep) new Crosscut sled for the table saw this evening out of want for a quick helpful project. However, it is not finished, the rear support has not been trimmed and installed, so it is not very stable when being lifted off the table. If you need to use the table saw before I am able to finish it, PLEASE BE CAREFUL SO IT DOES NOT GET BROKEN IN HALF.
The rear fence is two pieces of MDF thick, so it would be perfect to put a double T-Track on top with a measure tape in one so you can set a stop block at whatever distance you need from the blade.
Let me know if anyone has any other ideas for improvement!
Kevin McLeod
