The Big Laser is Almost a Laser Again.
Done Tasks
Installed Mirrors and Lenses
Install Leetro Controller and LaserCut2017
Checked 220 VAC wiring, keyswitch, estop, power supplies. Found and replaced burned out fuse.
Gantry LED Lighting now works
RedDot aiming Laser now works
Rehung the cabinet doors
Chiller is plumbed to run through both lasers
Exhaust fan is attached
NOTE: If you are going to use the Small laser Sunday night 9/22, Plug the chiller and exhaust fan in to the Yellow 220 Outlet box. (Ieft them unplugged)
To Do Tasks:
Make adapter bezel for mAmmeter and install - Laser cut on small laser or 3D print. We need this NOW
Hook up air line feed
Install belts on X and Y drives
Test Power Supplies, stepper drivers, stepper motors and limit switches. (probably will do Monday)
Test fire old laser tube - Maybe install new tube.
Align Laser, mirrors and lens - this task needs two people to go faster
Test cuts
Tasks to do after the laser is up and running.
Install replacement lid struts
Install Ruida Controller - It’s ordered and due in by October 10
Document LightBurn use
Train Members on new updates to Laser Cutter
