It look like the laser sensors are in. Do we need to machine a bracket?
If only we had some machining capability. ![]()
Brad “not a machinist” Walsh
I have access to a 5 axis Haas that can fit 30x24x12" ?
Ha.
I have access to an old RF31 with DRO. ![]()
I think the bracket would be in the 10mm x 30mm x 3mm range.
Don’t know exactly what is needed. The new sensor is square so I don’t think the old bracket would work. Will probably need to design a new one. If only we knew some makers . . .
Brad “not jealous” Walsh
