Currently setup with 150 grit.
- drum sander
Belt and drum sanders are different machines. Just clarifying in case anyone may be confused
Heck, the PTDR group has a few belt sanders if you need one. ![]()
Doh! Thank Elly.
BTW, I ran a bit of pine through it, which seemed to be okay, but you might want to double check my work here. It was the devil’s own time getting the DAMNED paper installed. On a completely unrelated note, we now have a half dozen sheets of sand paper that are too short for the drum sander. Totally unrelated.
(And labeled as such on the back)
We can cut those down a bit and put them in the file folder of sand paper.
I’ll do a quick check on it while I am there tonight.
