There had been some discussion of getting band saw blades for the wood shop with the warden budget.
I would like to propose we get two (for spare) of the following 3-packs ($45/ea):
It contains the following blades (copied from Rockler website):
3/16" Wide Band Saw Blade 93-1/2"
- 3/16" width can cut a 3/8" radius circle
- 10 TPI offers the cleanest finish and the ability to cut thin stock
- Minimum material thickness of 5/16"
- Maximum material thickness of 3"
- Regular tooth - excellent chip carrying capacity in narrow bands
1/4" Wide Band Saw Blade 93-1/2"
- 1/4" width can cut a 3/4" radius circle
- Medium width offers stability for a wide range of cutting applications
- 6 TPI balances fast cutting with less saw marks
- Minimum material thickness of 1/2"
- Maximum material thickness of 5"
- Hook tooth - excellent chip evacuation in thick wood with a more aggressive feed
5/8" Wide Band Saw Blade, 93-1/2"
- 5/8" width can cut a 4" radius circle
- Wide blade offers maximum stability and beam strength for extremely straight cuts and resawing without “barreling”
- Thin kerf makes the work easier for your saw and produces less waste
- 3 TPI can rip through the thickest lumber
- Minimum material thickness of 1"
- Maximum material thickness of 6"
Kevin McLeod
