I am considering starting a project which will involve performing the following tasks, I’ve included what I assume to be correct.
I am looking first observe a signal coming through a wire.
0-10 mV Peak to Peak
0-1.5 mV rms
0-500 Hz Varying frequency range
50-150 Hz Dominant frequency range
If possible, I would like to be able to remove noise from the line and clean up the information.
20-500Hz (Maybe 20-400Hz)
12dB/oct
I would like to be capable of recording the signal.
I hope to be capable of amplifying the recorded signal and sending this same signal back out.
Any common signals would be filtered, while differential signals would be amplified.
A minimum of two channels will be necessary, I may even need somewhere close to thirty channels later, scalability
At the moment it is not necessary to able to perform these from an external battery but this would be an end goal…
Which modules/shields would you suggest for these activities, As a budget cap I would prefer to stay under $100 but willing to go to $250 if I’m using well documented modules/shields which would be quick and easy to setup. I am willing to use multiple modules independently or all in one modules if they simplify the process.
My preference is to minimize the coding necessary on my part, so well developed modules are preferred. What are your thoughts?
