I have a water pump that needs only 6" to 1ft of plastic tubing. I don’t feel like spending $25 to buy 50 feet when I only need 3/8"…
Does anyone have some scrap tubing? Must be higher pressure than the plain aquarium style vinyl tubing (only takes 45psi)
L
Do you care about the type of plastic? Flexible or stiff ok? Do you care about the OD?
I might have some 3/8 PEX at home. I also have some 3/8" ID x 5/8" OD PC water cooling flexible tubing in red, though I don’t remember what the actual material is for that.
It has to connect to a barbed fitting, so pex won’t be right. I found an old washing machine hose here with a 3/8 ID – I’m in process of cutting it and testing… Will let you know.
Washing machine hose hack works well. Holding pressure at 80psi…
Thanks for the iffer, though, Kevin.
