As part of the lounge renovation, I removed the air line going in there. I capped the one side of the tee that splits off the air for the CNC nail gun, so I shut off that entire side of the Hive off. It needs to stay off for a couple of hours so the pipe dope can set up - though by the time anyone reads this it should be good to turn back on. If you turn it on, just walk over there and listen for any leaks - you don’t have to climb up or anything; if it’s not audible from the ground, that’s fine. If no one turns it on, I should be around Friday night to do so.
