The laser cutter once again has a functional sighting laser! The lens on the old laser was damaged causing a really wide spread, so I replaced it with a new diode. The laser should be more resistant to vibrations thanks to some drops of hot glue in addition to extra-tight screws; it aimed true through all my cutting today. Special thanks go to my cats for sacrificing their laser pointer to the cause; they're the true heroes.
Thanks for doing this Thomas!
Let it be known that the cat’s toy will always be remembered! !!
