Okay. So here’s the history:
I bought the Ultimaker machine new and brought it down to Hive as a donation. I can certainly sign it over at this point if the board wants to give me the paperwork. It is a technicality, at the moment, though, that it’s not 100% hive property. It will be 100% hive’s own – I won’t take it back, nor do I care how it is modified after I leave Hive13 and move back home to New Mexico.
Ultimaker 2 extruder sucked. Notoriously bad with filament slipping, overheating and warping the PTFE coupling, no geared extruder, only 0.4mm extruder head (non-changeable nozzles). So please be aware it has been improved over “stock”. Everything printed on there is from Taulman Nylon and TECH-G. So don’t get me started about filament quality.
The belted extruder design is my own variation of a well known design. It increases speed and reduces filament slip. It is also easier to load. Most UM2 have the printed “robert’s” drive, like this machine.
Bowden has been upgraded to real PTFE, not kinda-slippery plastic that looks cooler.
I added the “olssen block” nozzle and hotend, which allows e3d size nozzles to attach.
Coupler to nozzle has been upgraded to a thermoplastic that allows printing to 260 degrees & doesn’t warp.
The pneumatic couplers (part that wore out) are far better than the stock.
Replaced the springs with bushings.
Replaced 20W hot end element with 40W element.
Plenty of other things I forget now.
I still have some spare parts including the printed parts so ask if something got busted and needs a replacement.
In this config, I can get it to print at 150mm^3/sec or more. Best it could do stock was 70 or 80. The firmware is an updated fork with lots of safety features. I had fun doing all of this, and it’s a hackerspace after-all, so it is hacked. Don’t misinterpret this as me expecting a pat on the back. Rather, it just ain’t easy to make a printer really “perform”, and takes detailed setup, maintenance, etc. The ultimaker is about as easy as it gets for ongoing maintenance. Before making changes, though, do ask some old-timers what the track history has been, though. I think Kevin S and Ryan H will attest that it’s better in current form than it was stock.
Only one harsh thing to say (and I don’t mean it to be too harsh): I haven’t seen anyone take the time to drive this printer a quarter as hard or well as a few of us did 4 years ago. So, before buying a new mustang, let’s try driving over 30mph first. I apologize, Jeffery, if I’m getting this wrong and you’ve been doing this – I haven’t been around a lot lately.
Anyway, a lot has happened in 4 years in 3d printer land, so this machine is solid, but older. A new printer might make more sense if folks want current features like 32 bit controller, etc. Could trade it in or sell it, maybe…
Lastly, Dave V, Jim D, and myself are going to resume building Hive’s next printer once Dave gets back from Europe and etc… It will happen. I don’t have this box of 15 0.9 degree steppers sitting on my desk for nothing…
So, I vote “abstain”, as it is Hive’s printer, and I’m not going to be around after August. Anyone may do what they will with it. However, I think some details are getting left out somewhere. I’d endorse anything that makes it work better than before, but first wouldn’t it be reasonable to see how well it can work now, and then thinking about spending money on it?
Opinionated-ly yours,
P.S. 1.75mm filament smokes 3mm in most areas. The retraction issues, availability, reliability, etc were all issues in 2012-2013 (I preferred 3mm then). Nowadays, better drivers, geared extruders, better hotends, consistent filament, better steppers, etc have made this possible since 2013. 3mm filament has a greater circumference in the bowden making more friction. The pressure required to squeeze sausage out of an orifice of 0.4mm or 0.25mm is substantial. This pressure, on the hob, bwden, motor, etc is reduced many fold by narrower filament (it’s easier to squeeze a thin thing into a thinner thing than a thick thing into the same).
